Bushes and scrub added to snake rail fence bases and ACW BUA base.
Kitty litter boulders now on the Swedish bases too. Insomnia has its uses, I suppose.
Almost finished the second set of big things (didn't help I added 3 extras to them that took most of today to fettle).
Bases of snake rail fences flocked, so they'll be dry and finished by the morning. Also more basing of my mid-19thC ImagiNations armies which I think are almost complete. Then it remains the small task of painting them!
Spartans and Greek peltasts have the usual Triassic-looking vegetation now. Hope to complete undergrowth on Greeks today.
Remind me.  :-\
Did we end up HAVING to have this sequel to 'A Tale of Four Gamers', because the original was "Too Full" ?
(If that WAS the case, we're probably half way there, again.)
Thracian and Moghal bases getting their upgrades.
Quote from: mad lemmey on 07 February 2020, 12:18:45 PM
Yes.
Ta, Will  :)......That means this one is about half full then.
As far as contributing to the thread properly is concerned....I've been soldering some frames up for some of the bigger models for Warband......(It's bloomin' cold in the pole barn today.)
Putting together some "Caesar" 20mm German Infantry, hard plastic. THIS IS A WARNING - avoid they are very fiddley and some have silly poses.
Anyway....
Bases highlighted and sealed, should be tufted, flocked and scattered later.
Two tiny things finished apart from labels.
Batch of Star Wars Armada fighters undercoated.
Life has been a bit busy this week, hence a drop in output of late.
Le porcelet gras, a small rocky island of Cap S. Michel, is ready to endanger shipping tomorrow.
Adding grit to the bases of my ImagiNations armies and one nearly finished, the other one may get started tonight...
Quite a lot of stuff finished today.
Also, star fighters base coated and inked.
Unit of 18 Hausa heavy cavalry almost finished too, just details/shields and bronze to do.
No idea why, just thought I should.
Hausa unit painting done.
Star fighters had two layers of highlights.
