"Stick 'em in the eye!"
Started by Duke Speedy of Leighton, 19 October 2016, 07:46:12 PM
Quote from: mad lemmey on 16 November 2016, 07:44:26 AM
If you count strike cruisers, I can do 4000 points now, just got to paint it (and rebuild a mk1 titan).
Buying it is only the first stage!
Painting it is quite significant- but pretty quick for epic. Although all those details you are adding will take time!
See what you mean, four assault stands painted in an hour and a half tonight!
Not a recent paint job but ... can you tell what they are yet? :)
Look like Judge Dredd type figures ?
(Said he, guessing wildly.)
Subedai
Not a clue what they are, but they look nice.
MickS
Blog is at
Alternate armies "Lawgivers" methinks. 15mm Sci-Fi
"I can't believe it's not Dredd!". All the buttery goodness of real Dredd with none of the artery clogging IP costs.
Very tasty - what's the middle infantry stand though, I just can't make it out properly - some sort of heavy weapon or Riot Foam projector?
Im liking the Dredd figures, are they 15mmlike Ian suggests, I thought they looked like 6mm?
6mm GW Epic 40K Imperial Guard - back when they WERE Imperial Guard and not the "Astra Militarum."
Mainly just a paint job though the Judge in the centre of the command stand has an eagle from a standard top added to his helmet. His gun is just a typical GW hugely oversized pistol.
The figure in the centre of the leftmost rear infantry unit is supposed to have a Riot Foam launcher.
The two infantry stands on the right are armed with shock rods and riot shields, the latter just being slivers of plasticard.
Somewhere there are Gorgon transports for them too. Bulldozer blades are ideal for removing rioting crowds!
Like these ... but blue :)
Great work with paint job conversions.
Were are the bikes from?
Quote from: fred. on 17 November 2016, 08:17:21 PM
Thank you.
The bikes are from the same plastic set as the guardsmen.
Cool - I've not seen them in IG armies. They may have disappeared over the years from the lists.
Cor, I remember that era of Epic, and would never have twigged! Amazing what a paint job can do :D
Try again...
Whirlwinds
Assault Marines
Two more Land Raiders
HQ and Termies
Devastator stands
More tactical bods
