19th Century bands
Started by cameronian, 23 August 2016, 12:39:36 PM
Subedai
Blog is at
Those look great. 8)
 :-bd =D> :-bd =D>
Hardly "feeble efforts", you shouldn't be afraid to blow your own trumpet  ;) ;D
cameronian
160 bandsmen winging their way to Fernando, very simple headgear conversions (with a file) have produced Austrain Bands (original) Prussian Bands (in Jaeger green) French Bands and Saxon bands, going to use them to indicate formation attrition (FOB 2 rules) easier than keeping a chit and less prone to 'mistakes'.
Excellent, I'll look forward to seeing some pics of those at some point!
As a FOB2 player I find that idea intriguing.  How do you actually intend to use them for formation attrition?
cameronian
I have based everything to fit in with my modified FOB 2 system, each base represents 3 integrity points, for every 3 point loss of integrity I replace a normal base with a distressed one, it has fewer figures and a few casualties on the ground. For each 3 integrity point loss I remove one bandsman from the band base (the band base depends on nationality, Austrians, Saxons and when we do the FPW, Bavarians will have one band per brigade; depending on how many bases the brigade has determines the number of bandsmen, an Austrian brigade has 18 bases including the brigade battery, so that translates into six bandsmen, a Saxon brigade has 14 bases so we give them 5 bandsmen. The Prussians and the French will have divisional bands of between 11 and 12 figures.
Sounds like a great idea. Usually find keeping track of the divisions and brigades gets forgotten about during play.
cameronian
Indeed, hence the bandsmen  :D
cameronian
12 March 2017, 01:19:44 PM #41 Last Edit: 12 March 2017, 01:21:43 PM by cameronian
Hope this works.  Was in  two minds re the bandsmen, each figure represents 3 integrity points, lose three lose a bandsman, dice on leadership card for outcome when depleted. Mounted them initially - front bases, then thought how much easier to base with brigade command figure - back Austrian base. Back base not properly flocked yet, comments please(should have pointed out on magnetic bases).
www.flickr.com/photos/55665103@N03/
Questions like this should be banned!
Good work chap.
I was going to suggest a good one would have been Johann' The Jive' Strauss and the Waltzettes
Didn't think there were any bands till after the Beatles in the 1960's....
