04 December 2020, 02:23:57 PM
311198 Posts in 18073 Topics by 2271 Members
Latest Member: Simon@TWZ
| | |-+  2mm clear acrylic sheet
Pages: 1 [2] Go Down Print
Author Topic: 2mm clear acrylic sheet  (Read 3524 times)
Glorfindel
Captain
« Reply #15 on: 15 July 2016, 05:39:54 PM »
I wonder if this stuff is solid enough to use as a base for terrain ?   The reason
I ask is that I am on the hunt for a source of material with similar properties to
2mm thick HIPS (High Impact Polystyrene Sheeting aka Plasticard).   This sort
of thing :
http://www.antenocitisworkshop.com/080-sheet-styrene.html
I can't help thinking that there are similar materials out there and am
wondering if acrylic sheet would do the job ?
Phil
« Reply #16 on: 15 July 2016, 06:11:21 PM »
Are you sure it was acrylic, as shed windows etc are normally made from polycarbonate as they are shatter proof and much more UV stable?
2017 Paint-Off - 2 x Winner!
« Reply #17 on: 15 July 2016, 06:20:29 PM »
It would work for terrain basing, as long as the terrain is not too big, as it has some flex to it. But it's probably more expensive than plastic card.
I have seen it mentioned that sign writers often have off cuts of various materials that would work for basing.
You may well be right, I'd have to go and check.
I probably assumed it was acrylic as that is what clear plastic rod is made from.
« Reply #18 on: 15 July 2016, 08:01:58 PM »
If it desolves with 'norma'l plastic glue, then it will be acrylic. If not, more than likely polycarbonate.
« Reply #19 on: 15 July 2016, 11:06:29 PM »
Signwriter supply companies sell plastic card (styrene) in very large sheets, from memory 1.2mx1.6m
Cost here is the equivalent of UKP20. I use it for all my basing and terrain bases, a sheet typically lasts me around a year
Glorfindel
Captain
« Reply #20 on: 16 July 2016, 10:00:08 AM »
Thank for the good idea - much appreciated.   Off to Google !
Phil
Pages: 1 [2] Go Up Print
