Learning to Sculpt
Started by Watts, 17 June 2016, 12:57:19 AM
Watts
Today I took the plunge and decided to try and sculpt a model of my own (in 10mm, of course  :D). I was a bit inspired by the Wildlings in Game of Thrones so I whipped something up, and learned a lot in the process... I had loads of fun so I think I'll try some more. Here he is:
Impressive Watts!  Really well proportioned. What is the material you are using?
Watts
Thanks! I used Beesputty for this one, first time using it. I like it a lot!
That looks excellent for a first attempt, as d_guy says the proportions are really good which is one of the harder things to do.
I'd say you have a talent worth encouraging there. But I'm disturbed that your first choice wasn't that dishy redhead ("You know noothin'. John Snow.").
 :-bd =D> :-bd =D> Impressive
Quote from: FierceKitty on 17 June 2016, 03:24:48 AM
Would the proportions on that one have been even more challenging ;)
Really impressive...Especially as it's a first attempt.  :-bd
I keep meaning to have a go with Beesputty (that's the one that has to be 'cooked', isn't it ?).....But I'll probably stick with Greenstuff and ProCreate, for the time being.
Very nicely done
Phil what sort of pro tipswould you have for the beginner?
I am thinking along the lines of,
Best value for money when it comes to buying  first aid kits
Which A&E is best at removing drill bit and scalpels from various body parts
Cheers in advance
Excellent work, even more so given it's your first attempt.
Quote from: Fenton on 17 June 2016, 07:29:15 AM
Very nicely done
Cheers in advance
;D ;D =D> =D>
barbarian
Beesputty is good but slightly expensive.
Problem is that it's like Fimo and Super Sculpey, so cannot go in direct vulcanisation, adding a step and adding cost : Not something you want on 10mm where the margin is low.
Very well done for a first attempt. Keep going.
Yes, (now that I've got over Fenton's witty comment), that is a good first attempt.  :-bd
17 June 2016, 10:10:02 AM #13 Last Edit: 17 June 2016, 11:11:09 AM by Techno
Cheers in advance
Techno's top tips.
Always make sure you have at least three spare packets of plasters in the medicine cabinet.
Don't try and 'pull' any broken drill bits from your finger or thumb with a strong magnet.....I've tried this, and it doesn't work.
That's cracking - loads of character and nicely proportioned with excellent detail!
