10mm or 15mm Gorilla/Yeti
Started by GrumpyOldMan, 24 March 2016, 11:16:33 PM
I was just looking around for a Yeti and I haven't found anything yet. Does anybody know of any 10mm/15mm Yeti or Gorilla figure?
24 March 2016, 11:22:33 PM #1 Last Edit: 24 March 2016, 11:25:17 PM by Ithoriel
I was planning on using DN60
http://www.pendraken.co.uk/DN60-p6382/
Copplestone (now from North Star) do a 15mm scale Yeti set but they are basically 25mm scale figures. Nice models but awfae big fur a 10mm yeti IMHO.
Hello Ithoriel
Thanks for the info. I didn't think about that #-o.
I did find some apes from a rival company but I think they may have been too small. 15mm.co.UK have an ape but at 18mm tall may have been too big.
Thanks again. Cheers
O Dinas Powys
Quote from: GrumpyOldMan on 25 March 2016, 03:38:43 AM
Hello Ithoriel
If 18mm is too big then DN60 is going to be much to big! There's a skull on the base to give you some idea of scale, but from memory it's around 25mm in height! If I remember - and can find where they are - I'll measure mine later.
Cheers!
Meirion
25 March 2016, 09:23:21 AM #4 Last Edit: 25 March 2016, 09:25:19 AM by FierceKitty
Ask Irregular Miniatures; it's the sort of thing they'd be likely to have. There's a King Kong pack for Tusk in 6mm that might be right up your tree.
Hello O Dinas Powys and FierceKitty
Quote from: O Dinas Powys on 25 March 2016, 08:17:04 AM
Cheers!
Meirion
Thank you. If you can find them (and somebody else hasn't tidied up and forgotten where they've put stuff - a particular bugbear of mine) a measurement would be appreciated.
Quote from: FierceKitty on 25 March 2016, 09:23:21 AM
Thanks. I did have a look through their ranges but, as usual, if it wasn't bleeding obvious - it eluded me  :D. Of course they'd need a giant ape for a King Kong pack  #-o
Now that I've got some info on the Indus and Shangri La army lists for Warmaster, I thought I'd get look at coming up with a Tibetan type list using Late Roman cataphracts for the knights and Mongols for the hoi polloi. Will have to decide now whether the Yeti are ogre type infantry or monsters - figures for both available now ~X( - The other manufacturer, which shall be known by the alias MM, also has a giant ape in their 15mm range.
Might use some of the brass amulets from this ebay seller as well -
http://stores.ebay.com.au/nagabronzestatue/
Pic of some of their amulets with Copplestone infantry and Pendraken cavalry below
O Dinas Powys
Quote from: GrumpyOldMan on 25 March 2016, 09:28:37 PM
Cheers!
Meirion
Luckily I'd put them in a logical place!  :D
Unfortunately the Frost Troll is ~20mm to the top of its head, so yup, even bigger than that ape  :'(
Cheers!
Meirion
The hoi poloi. Hoi means the already.
Plan B ... import from the US and risk the stupidly expensive charges.
Wildmen of the Savannah from Khurasan - sculpted by Phil Lewis apparently
Stop, Dave...will you stop, Dave? My mind is going...I can feel it....
O Dinas Powys
Quote from: Ithoriel on 26 March 2016, 01:13:41 AM
VERY nice  :-bd
How tall are they Phil?!  :-\  ;)
Cheers!
Meirion
