25 October 2020, 02:37:56 PM
308783 Posts in 17958 Topics by 2266 Members
Latest Member: michaelk
| |-+  Requests
| | | |-+  SYW range
Pages: 1 2 [3] 4 Go Down Print
Author Topic: SYW range  (Read 14251 times)
Zbigniew
« Reply #30 on: 06 May 2010, 07:29:47 AM »
And I have found one more reason for SYW French in turnbacks - they could be used also as Spanish or Portuguese infantry. Wow, I could make the siege of Havana!
kustenjaeger
« Reply #31 on: 17 May 2010, 12:20:18 PM »
Greetings
1. Exploring the AWI range I presume that we can use the 5.5" howitzer for the lighter SYW types - at least in Western Germany - filling in the absence of howitzers.
2.  Could the SYA32 Mounted Grenadiers pass for French cavalry in bearskin (volontaires or some regular chevaulegers regiments as time wore on)?
3.  Does anyone know what the key differences are in uniform/equipment between the SYW Prussian jagers and the AWI German jagers?   I'm currently using SYP codes for SYW Hessians and Brunswicker line infantry 1757-60.
Regards
Edward
Viscount
« Reply #32 on: 20 May 2010, 06:19:44 PM »
1.  Yes, although you might need to change the wheels?
2.  Yes, should be fine.  The command figures are in Tricorn.
3.  Not sure, might need someone else to jump in on this one.
Zbigniew
« Reply #33 on: 21 May 2010, 06:25:02 PM »
Greetings
Edward
my advice is to use French heavy cavalry figures. All you have to do is getting rid of tricorns delicately and then attaching blob of green stuff - which can be hard or easy depending on how fussy you are Smiley
I wouldnt advice using SYA32 fore these. There are many minor differences. Remember that French horse in bearskins formally were not horse grenadiers but cuirassiers. SYA32 have muskets while French heavy horse had carbines etc.
Here you have a few pictures of my green stuff conversions:
In second row is unit of Nassau-Sarrebruck heavy horse made of French heavy cavalry figs (with one or two converted prussian cuirassier figure added)
In the first row are Volontaires de Schomberg made of British light dragoons and Prussian Bosniack lancer figures
lentulus
« Reply #34 on: 15 June 2010, 03:30:43 AM »
Like it says on the box.  7 and 18 pounder.  Please?   Cool
Viscount
« Reply #35 on: 15 June 2010, 06:40:31 PM »
I've popped those on the list.  There's always the 5.5" Howitzer in the AWI range, which we could supply with SYW crew?
lentulus
« Reply #36 on: 15 June 2010, 07:26:49 PM »
I'll give it a try with the next order.
Viscount
« Reply #37 on: 15 June 2010, 08:22:21 PM »
Good stuff!
Zbigniew
« Reply #38 on: 05 July 2010, 04:12:55 PM »
Leon,
Can we expect any addons to the SYW range this year?
Is any of your sculptors interested in making SYW figures now?
Viscount
« Reply #39 on: 05 July 2010, 07:22:58 PM »
With the ranges being quite comprehensive, there's not a lot planned for them.  The only thing I could see us adding before the end of the year would be the French with turnbacks, as quite a few people have requested them.
Zbigniew
« Reply #40 on: 26 July 2010, 11:34:30 AM »
Leon, I know you have many other sculpts to do. However, would it be possible to relese at least one new French with turnbacks figure soon (say, advancing or marching pose) and the rest later or even next year?
I guess it wouldnt be a problem to experienced sculptor and we could have something to go on with.
I have a whole huge French army already completed (around 800 figs), but ther is a big hole in my army, because I dont have a single forign infantry unit in it.
Please dont force me to make green stuff turnbacks myself for some 200 figs I need  Wink
Viscount
« Reply #41 on: 26 July 2010, 03:54:22 PM »
We'll be getting something done.  I think I mentioned a while back that we're looking at setting a month aside to get a load of odd bits and pieces done.
Zbigniew
« Reply #42 on: 26 July 2010, 04:53:34 PM »
Ok, I will be very patient   :Smiley
leadman
« Reply #43 on: 26 July 2010, 07:57:59 PM »
Can I use Austrian Dragoons for Austrian Cheveaux Leger?  If not, can you add them to the list?
Thanks,
Leadman
Zbigniew
« Reply #44 on: 28 July 2010, 09:58:10 AM »
Thanks,
Leadman
I exactly use Austrian Dragoons figures for Austrian CheveauxLeger. There were no differences in uniform cut between these in reality. The only difference was that chevauxlegers used cheaper, lighter and more agile Polish-type horses. Most Austrian dragoons used heavier and stronger mounts like cuirassiers.
I hope it helps,
Pages: 1 2 [3] 4 Go Up Print
