How many at once?
Started by alexmac207, 24 February 2016, 09:48:43 PM
alexmac207
How many figures do you usually paint at the same time?
I thought by unit would be a good way, at first. I started off with a unit of 8 cavalry and
that went well. I am currently working on a 30 man unit of Grenadiers and I'm feeling a bit
overwhelmed. It seems like I am getting very far when I paint each day.
Any tips or tricks for getting the job done without losing your mojo?
It varies from one project to another, but to give some examples:
ACW
One unit for me is 32 models on 4 bases. So i paint 32 at a time.
ww2
usually all at once, because i distribute them afterwards and stick them to bases. Easier to do all at once, so i can mix and match to get as many different poses on each base.
For skirmish games.
As many as i want at the time i paint, but will usually do 50/50 for both armies, to keep the force sizes consistent. (i always do both forces for my games)
Sometimes I paint a single figure/ model. Sometimes two or three units.
If it starts to feel like a chore because I'm doing too many at once, I'll concentrate on part of the group.
So, in answer to how many at once - as many as I feel comfortable doing at that moment.
It's a hobby, not a job, so I just go with the flow.
Today I have a unit of twenty 28mm figures, eight units of twentyfour 6mm figures and fifty markers based on coins covered in pebbles.
I paint a little bit on each every day.
I sometimes have more than this on the go at any one time.
I tend to paint in large batches, 81 cavalry on the go at the moment.
I set sub goals, for example I've just finished dry brushing the uniforms and will move onto the horse's manes and tails next. I won't worry about what is next until they are done.
Doing something every day, if you can, gets you there in the end ;)
I have also found a painting diary on this forum helpful with maintaining motivation, if not always focus ;)
I tend to go with batches of about 30 foot at a time - I find this the best balance between too many and getting overwhelmed, and too few to see the results.
But the key is to go with what works for you, if 8 cavalry is good, then I'd try about 15 infantry at once.
Zippee
I tend to do one or more units, so recently that has been an Napoleonic Austrian infantry regiment (144 figs) whilst now I'm on the cavalry and doing a couple of regiments at a time (32 or 48 figs).
That gets turned around in a week generally.
I do an hour or so most weekday evenings - one or two colours or 'things' across the whole lot and then at the weekend a concentrated stint to finish, base and prep the next batch.
Usually about 50, two units.
I paint in batches of 20 to 30 figures any more and I find it to difficult
Having recently painted up some additions to a couple of units, AWI riflemen, I would suggest doing complete units as a minimum
Even with good painting notes it was "interesting" getting the extra stand to blend into the unit. I suspect it would be even harder for more uniform units.
Shecky
depends on what I feel I can handle at once. For instance, the SYW Austrians units I just finished I painted two units or a total of 28 figures. The most I ever tried at one time were 84 ACW Union figures. Those were easy as they were all the same. The more details or colors I need to use the fewer figures I paint at one time.
Obsidian23
Hi,
I find doing them by unit.  I am painting British AWI so this is relevant to that only.  I am new to 10mm and found doing 6 stands of 6 figures  works.  I can go from 0 to based and finished in one sitting.  The technique I use which helps keep me on track and makes me feel like I am making progress is to pick a colour or uniform part and do that.  so I would do the white, so I start with the base grey and then the white highlight, I would do the trousers, undershirts, belts etc.  Once the white is finished pick the next colour and go.  I have some posts up called my First 10mm.  all of these were one in a couple of days.
hope this makes sense and helps.
cheers
Depends upon the rules sytem I'm using. So for BKCII, it might be 9 stands of infantry at 4 figures per base. For Honours of War, more likely 2 bases at a time, with 8-10 figures per base.
