30 March 2020, 01:43:26 PM
Blitzkrieg Commander IV is now available here!
294410 Posts in 17434 Topics by 2206 Members
Latest Member: Stewart
|-+  Pendraken News & Info!
| |-+  General Pendraken
| | |-+  Old Newsletters
| | | |-+  July 2015 Newsletter!
Pages: 1 [2] Go Down Print
Author Topic: July 2015 Newsletter!  (Read 11221 times)
barbarian
« Reply #15 on: 08 August 2015, 12:19:12 AM »
That's really cool.
mad lemmey
Marquis
« Reply #16 on: 08 August 2015, 12:39:56 AM »
Oh wow!
Brilliant
Off to the Shed of Decency.
Viscount
« Reply #17 on: 08 August 2015, 03:04:01 AM »
That looks fantastic!   Shocked
« Reply #18 on: 08 August 2015, 05:09:15 AM »
 Thumbs up Applause Thumbs up Applause Thumbs up
Count
« Reply #19 on: 08 August 2015, 06:44:06 AM »
That really is excellentThumbs up Thumbs up Thumbs up
A +, Matt !
« Reply #20 on: 08 August 2015, 08:28:51 AM »
Wot, no fish? Wink
« Reply #21 on: 08 August 2015, 08:33:51 AM »
(In other words, I'm a deep green from head to toes.)
ianrs54
« Reply #22 on: 08 August 2015, 10:57:52 AM »
Wot, no fish? Wink
Or surfers Huh??
Matt J
...nana?
« Reply #23 on: 08 August 2015, 11:41:04 AM »
thanks guys
and there are fish, they are in the reeds (no surfers though)  Wink
now the web pic is done I'm going to pimp this - extra crew, weapons, stowage etc.
Beep
Heedless Horseman
« Reply #24 on: 09 August 2015, 12:52:21 AM »
Now, that PBR looks fantastic!   Cool
O Dinas Powys
Blowing up a storm!
« Reply #25 on: 09 August 2015, 11:11:53 PM »
Fantastic work, what did you use for the water?
(I know, even though it's fantasy  Shocked  Wink  )
Matt J
...nana?
« Reply #26 on: 09 August 2015, 11:30:10 PM »
Woodlands senics E-Z water, basically glue pellets from the looks of it. Just melt and pour and then used a soldering iron once set to add ripples etc.
Beep
O Dinas Powys
Blowing up a storm!
« Reply #27 on: 09 August 2015, 11:36:35 PM »
Cool, it looks great.  I've seen it in the past, but never had quite had a project in mind to use it.
What did you use as a frame to hold it 'in' the base?  Masking tape, tin-foil or something else?
Meirion
Matt J
...nana?
« Reply #28 on: 13 August 2015, 03:19:13 PM »
Apologies for the delay Meirion
Minibits Palm trees come in little plastic tubs the base of which are the same diameter as the base of the model. So I made the base - pva, sand paint and static grass put it in the bottom of the tub then poured the 'water' over then quickly stuck the boat on top. Break the container off then tidy up the water with the soldering iron.
It took 2 attempts (and 2 bases) before I got it right. Even then I ended up with a large air bubble under the prow which had to be filled. Not an easy job.
Matt
Beep
O Dinas Powys
Blowing up a storm!
« Reply #29 on: 13 August 2015, 03:26:31 PM »
Matt
That's okay Matt, thanks for the info.
It gives a really clean edge which other options might not do   Cool
Also good to know that cheap polypropylene can survive the heat Smiley
Meirion
Pages: 1 [2] Go Up Print
