What type/make/size brush(es) do you use?
Started by getagrip, 10 February 2015, 10:09:47 PM
Sorry to be so long !.....
Size 0 & 1 for just about everything.....VERY occasionally 00.
getagrip
Quote from: SV52 on 10 February 2015, 11:13:49 PM
W&N Series 7 S1,2,3.  I find a good point is the most important criteria, in my experience too small a brush doesn't hold enough paint and with some acrylics it's dry before you can apply it, unless you're quick.
Agree with you completely on this; that's why I use 1 or 0.
getagrip
Quote from: Matt of Munslow on 11 February 2015, 12:37:48 AM
GW brushes as I use their paints and their brushes are the only ones I've found to work with them.
I have to go in the shop though to go through the best points and the standard has dipped last couple of years. Started using a new one tonight, nearly threw the f**king thing through the wall!
The "point" disappears far more quickly than they used to; the reason I like GW brushes though is the resistance and thickness of the handle.
Have they chunked the handles up, now ?
The early ones were too narrow for my liking, which is why I stuck with the Windsor and Newton brushes.
The bristles were longer than I liked, too.
getagrip
Quote from: Techno on 11 February 2015, 08:02:08 AM
Pretty much the same they've always been Phil  ;)
Never used W&N but bristle length is key; cannot stand brushes when the tip is "sloppy" (and if that's not an open goal for Nobby, nothing is :) )
Hmmm...
Have to say that when the first batch arrived at the studio, I didn't like them nearly as much as the W&Ns....So like most of the others, I stuck to those.
One of the painters DID prefer the GW ones, as he liked the fact that the bristles were a tiny bit longer.
I use "The Works" 4 for £1.99  for the majority of my painting. they do fine detail brushes for general painting  and flat ones that are good for drybrushing.
I also use the Pro Arte range which hold the point better for fine detail work
The Works  ones don't keep a point as long as the Pro arte ones but are a less than a quarter of the price, so i buy three packs at a time and throw them away reguarly.
For Bases, buildings and terrain  I use flat brushes from "Tescos" that are flat brushes about 8mm across and only £1.50 for three. They paint quick and are brilliant for soft drybrushing .
I also use a 1 inch Flitch (windowframe Brush ) for terrain from a DIY store
barbarian
Size 2.
Rarely size 0.
The size doesn't matter, it is the tip that matters.
8) :o
when painting 10mm -
[Undercoating]
Army Painter Monster brush
[Miniature Painting]
Army Painter Basecoating brush (majority of the painting)
Army Painter Detail brush (faces)
[Drybrushing bases]
Foundry Drybrush brush
[Shading washes]
Foundry Blocking brush
I also use GW brushes. The first "detail" brush I bought (about eighteen months ago) was brilliant, but the replacements have been fairly so-so. I also use a 000 sable kolinsky from J P Perkins that I bought from the local art shop. It's now started to "hook" after a couple of weeks use.
Matt J
QuoteIt's now started to "hook" after a couple of weeks use.
Why do they do that  >:(
That's why I use GW no matter their other faults, they never hook.
Beep
getagrip
Quote from: barbarian on 11 February 2015, 11:47:23 AM
Size 2.
Rarely size 0.
8) :o
Agree to a point (no pun intended), the length makes a significant difference to me :-\
