23 September 2020, 03:54:32 AM
307208 Posts in 17879 Topics by 2260 Members
Latest Member: JP
|-+  Minibits Topics
| | |-+  Clear Acrylic bases
Author Topic: Clear Acrylic bases  (Read 7949 times)
Major General
Thread Derailment Specialist
« on: 29 January 2015, 07:34:27 AM »
Hi  Leon
We have been discussing this at the club and bases for vehicles would look much better if they were clear acrylic so you could see the terrain colour through them.  It looks a bit naff to have a vehicles based on grgass/mud driving through a town. but an acrylic one would be fine.
I like to base them to keep peoples fingers off the Models
Can your laser cutter cut acrylic bases?
Moderator
Viscount
« Reply #1 on: 29 January 2015, 01:58:29 PM »
It can indeed, although the acrylic is pricier than MDF so they'd be around 3x more expensive.  Let me know if it would be of interest and we'll have a look at getting some acrylic in and doing some test runs.
Major General
« Reply #2 on: 30 January 2015, 07:21:48 AM »
Yes I am seriously interested , might also need to see how easy it would be to stick them to the acrylic without making the rest of the base cloudy
 What thickness would the material be?
« Reply #3 on: 30 January 2015, 08:52:07 AM »
What you need is model glue for cars and stuff (they tend to be non-foggy for use on windows and such)
for example:
http://www.benl.ebay.be/itm/ZAP-POLY-ZAP-GLUE-DRIES-CLEAR-14-1g-LEXAN-ACRYLIC-HOBBY-AUTOMOTIVE-CRAFT-PT-22-/150891991367?pt=AU_Toys_Hobbies_Model_Kits&hash=item2321dd1147
What would also work is craft glue for beads and gems, they are supposed to dry clear too, but i don't know if it's strong enough to take metal models  Undecided
http://www.benl.ebay.be/itm/Gem-Tac-Glue-Pickup-Pencil-500-Rhinestone-Flat-Back-Acrylic-Crystals-3mm-4mm-/151209499257?pt=LH_DefaultDomain_3&var=&hash=item2334c9da79
Another thing that might work would be nail glue (the one for putting fake nails on) but i wouldn't trust that as that's brittle.
« Reply #4 on: 30 January 2015, 11:09:53 AM »
Why not matt varnish the models, if handling them is the only problem, and forget about bases?
Major General
« Reply #5 on: 30 January 2015, 01:06:12 PM »
I like the idea of unbased vehicles - which is what I do on larger scales.
The base serves to keep them apart in the boxes I store them in, and as I do mainly early war a lot of the vehicles are a little small to handle without a base
Moderator
Viscount
« Reply #6 on: 30 January 2015, 01:20:06 PM »
It'd be 2mm, same as the current MDF ones.  We can get thinner acrylic, but the price almost doubles as you come down to 1mm thick.
ianrs54
« Reply #7 on: 30 January 2015, 04:14:58 PM »
Sounds odd - thinner costs more ?
WeeWars
« Reply #8 on: 30 January 2015, 04:23:38 PM »
https://hobarts.com/sheet-materials/acrylic/acrylic-sheet-clear_124_7_1/
www.supremelittleness.co.uk
Moderator
Viscount
« Reply #9 on: 30 January 2015, 04:24:27 PM »
Yeah, it's the same with the MDF.  Really thick (10-20mm) is expensive and then it gets cheaper as you come down through 8/6/5/3mm, etc.  2mm seems to be the most efficient and cheapest point, and then it gets more expensive again as you get thinner.  0.8mm MDF & plywood are both available, but they're 6x the cost of 2mm MDF.
I've always assumed that really thick is expensive because you're paying for the physical material, and then really thin is expensive as it's more laborious to produce?
EDIT:  WeeWars' post is the place we would normally use, so you can see the prices there.
WeeWars
« Reply #10 on: 30 January 2015, 04:28:40 PM »
There's also 0.8mm Clear Polypropylene.
https://hobarts.com/sheet-materials/polypropylene_124_2/8mm-clear-polypropylene-p-827.html
Major General
« Reply #11 on: 30 January 2015, 06:13:44 PM »
The 2mm stuff would be perfectly ok.
I don't mind being the guinea pig - what sort of anount do you need to order to give it a go.
what colour would the edges be?
Moderator
Viscount
« Reply #12 on: 30 January 2015, 07:19:12 PM »
I'd hope that they're clear as well, the lasercut acrylic I've seen elsewhere doesn't have any burns marks from the cutting process at all.  I'll remember to get some in and we'll let you know how we get on.  It'll probably be a couple of weeks though before we get to it though.
« Reply #13 on: 01 February 2015, 04:15:04 PM »
Could be handy for naval gaming too...
