Welcome,
Guest
. Please
login
or
register
17 January 2021, 12:48:40 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
The revamped
Feudal Japanese
have been released!
314300
Posts in
18203
Topics by
2277
Members
Latest Member:
Chalace
Wider Wargaming
Painting & Modelling
(Moderator:
Yet another basing query...
« previous
next »
Pages:
1
Author
Topic: Yet another basing query... (Read 3881 times)
Capt Sensible
on:
26 November 2014, 03:43:38 PM »
'Afternoon chaps,
A happy little event occurred in my household this morning: the arrival of a hefty package from Pendraken, stuffed full of Ottoman Turks.
As a returner to wargaming after a gap of 20 something years, I'm amazed at the variety of kit available these days. However, this does leave me in something of a quandry: what type of base to use for my lovely new toys?
I would prefer to use relatively thin bases with magnetic sheet. 2mm MDF plus stick on sheet looks too 'chunky' for me. I have seen mdf/magnetic bases advertised but this range does not cover the FoGR sizes I want to use:
http://wargamesbuildings.co.uk/epages/950003459.sf/en_GB/?ObjectPath=/Shops/950003459/Categories/Deluxe_Magnetic_Bases
Has anybody tried using those teeny-tiny disc magnets?
Would I be better off cutting 1mm plasticard to size and using magnetic sheet stuck on the base?
Any other suggestions?
I would be grateful for any advice you can offer.
CS
''No more curried eggs for me!''
Re: Yet another basing query...
Reply #1 on:
26 November 2014, 04:54:56 PM »
The problem with very thin basing is warping, and this is even more likely with plastic vis-a-vis MDF. Best plastic bases I've come across are those supplied by Peter Pig, but the sizes are very limited, and they are 2mm.
Reply #2 on:
26 November 2014, 04:58:09 PM »
I have had 1mm lasercut ply from Litko, 60x30 and its never warped
Litko do prebacked magnetic bases as well
The only problem unless your in USA the last time I ordered I got stung for import charges
Last Edit: 26 November 2014, 05:04:45 PM by Fenton
If I were creating Pendraken I wouldn't mess about with Romans and Mongols I would have started with Centurions , eight o'clock, Day One!
Reply #3 on:
26 November 2014, 05:01:01 PM »
......and very thin bases are difficult to pick up unless you have little, dainty elfin hands.
Reply #4 on:
26 November 2014, 05:07:07 PM »
Another option is
http://www.freewebs.com/pwsltd/steelbases.htm
or
http://www.productsforwargamers.com/bases.html
( I have ordered from these guys and are good)
Capt Sensible
Reply #5 on:
26 November 2014, 05:52:29 PM »
Thanks for your advice, chaps. I'm inclined toward pre-cut MDF with added magnetic tape but I won't buy anything until I'm ready to base the first batch. It may that I will come roud to the idea of thicker bases as I do not have elfin digits
CS
Reply #6 on:
26 November 2014, 06:17:14 PM »
If you want thin bases then steel is a very good option - I too have used precision Wargame supllies.
You can then magnetise your storage box.
You can use newer 'copper' coins if you need round bases as they are steel cored.
I looked at the pre-magentesed MDF bases recently, but they are a lot more expensive than buying the MDF bases and the magnetic sheet - but you do have the fairly easy job of sticking the magnetic sheet on the bases
2011 Painting Competition
- Winner!
2012 Painting Competition
- 2 x Runner-Up!
2016 Painting Competition
- Runner-Up!
2017 Paint-Off
- 3 x Winner!
Reply #7 on:
26 November 2014, 06:18:55 PM »
You also asked about small rare earth magnets - these aren't great for basing as they are quite thick. So you have to drill into the base and then often disguise the magnet on the top side.
They are strong - I have used then occasionally for holding sabot bases on.
- Winner!
- 2 x Runner-Up!
- Runner-Up!
2017 Paint-Off
- 3 x Winner!
Capt Sensible
Reply #8 on:
26 November 2014, 07:20:04 PM »
Thanks, Fred 12df.
CS
WeeWars
Reply #9 on:
26 November 2014, 08:27:05 PM »
I use self-adhesive steel sheet under my MDF bases. Adds no visible difference to the base thickness:
www.michaelscott.name/1809/1809blogpost164.htm
And easy cut to any size. I even cut circles with a rotary cutter. Always 1mm back from the edge of the base to keep the white sheet hidden.
I prefer 3mm MDF because I want gamers to pick up my minis by their bases not by my paintwork and modelling.
I stick self-adhesive magnetic strip to carrying cases. This can be as super strong as you desire.
www.supremelittleness.co.uk
2014 Painting Competition
- Runner-Up!
2015 Painting Competition
- Runner-Up!
Capt Sensible
Reply #10 on:
26 November 2014, 08:38:21 PM »
Thanks WW, I like your lateral thinking - thin sheet metal under the bases and magnets in the storage boxes!
CS
Major General
Sir Oik of Westmarch
Reply #11 on:
29 November 2014, 09:08:05 PM »
I once used postcard with a magnetised strip attached (I was kind of forced into this because the so called 6mm figures I ordered were more '10mm' so I needed to use a thinner base to try to compensate for the thicker bases used for the rest of my collection). Yes, at first glance, this is not a rigid solution. However, as I prefer to Milliput my bases so that the base of the actual casting blends in with the base and does not stand out, when I applied the Milliput and this dried I then had a rigid base. And because the base was magnetised, and I had placed the base on a flat metal surface, the Milliputted base had dried perfectly flat. Only problem with the postcard is that its flexibility was a real nuisance when applying the Milliput but I wonder if the plastic card option would solve that (you can also attach a magnetised strip to steel strips - I have done that and so, know that is also a solution).
Capt Sensible
Reply #12 on:
30 November 2014, 09:12:48 AM »
Thank you, Westmarcher.
CS
Heedless Horseman
Captain
Reply #13 on:
21 December 2014, 08:45:00 PM »
Not what you are asking about, but I have experimented with 25mm figures, putting magnets in holes in both the figure and mdf bases to allow 'old style' figure removal. Those thin (3mm) rare earth magnets are strong enough to keep a 25mm fig loosely in place during a game but not really for storage transport. A LOT of bother trying to keep polarity constant with multiple bases though! lol.
Capt Sensible
Reply #14 on:
22 December 2014, 08:23:54 AM »
Thanks for that, HH.
After footling around with bits of card and a copy of the FoGR rules I think I might be looking next at Impetus-Baroque. The reveiws suggest it is a bit simpler and genuinely 'fast-play', which is what I'm looking for. Another plus is the large bases and smaller number of figures needed - anything that gets an army painted and on the table quickly has to be good!
CS
Pages:
1
« previous
next »
Please select a destination:
Welcome
=> Forum Info
=> Intro's and Welcomes
=> Requests
Wider Wargaming
===> 20th Century
Pendraken News & Info!
=> Shows
=> Photos
Wider Wargaming
===> Fantasy & Sci-Fi
=> Rules
Non-Wargaming Discussion
=> Chat & News
Wider Wargaming
=> General Discussion
=> General Pendraken
=> Fun Stuff
Wider Wargaming
=> Painting & Modelling
===> Painting Diaries
=> Batreps
===> Clubs/Societies
===> Sport
Wider Wargaming
===> Dungeons
=> Books
===> Scenics
=> New Figure Previews
=====> 2010 Show Stuff
Archive
===> PPC 2011!
===> WW2 Requests
===> WW1-SCW Requests
===> Fantasy/Sci-Fi Requests
===> Fantasy/Sci-Fi Photos
===> WW2 Photos
===> WW1/SCW Photos
Archive
=> Competitions
Welcome
===> In the Line of Fire!
Minibits Topics
=> General Minibits
Wider Wargaming
=> Resources
=====> 2011 Show Stuff
=======> 2010 & 2011 Previews
Archive
===> PPC 2012!
===> 18th Century Requests
Wider Wargaming
===> Blogs
Archive
Wider Wargaming
===> Downloadable Rules
===> Resources - 20th Century
Archive
=> The Big Move
=====> 2012 Show Stuff
Archive
===> PPC 2013!
=======> 2012 Previews
Wider Wargaming
=> Non-Pendraken Stuff
=====> 2013 Show Stuff
=======> 2013 Previews
Archive
===> PPC 2014!
===> Smoggy '13!
Pendraken Rules!
=> Warband
=======> 2014 Previews
=====> 2014 Show Stuff
Archive
===> PPC 2015!
===> Post-War/Modern Requests
Wider Wargaming
=> Genre/Period Discussion
=> Networking
Pendraken Rules!
=> Cold War Commander
===> BKC-III
=> Future War Commander
=> New Releases
=======> 2014 Releases
=======> 2013 Releases
=======> 2012 Releases
=======> 2010 & 2011 Releases
Archive
=> Battleground
===> Battleground 2015!
===> Old Newsletters
=====> 2015 Show Stuff
=======> 2015 Releases
===> Previous Years
===> Previous Years' Releases
===> Previous Years' Previews
=======> 2015 Previews
Archive
===> PPC 2016!
===> Battleground 2016
===> Pendraken Website Photos
=====> 2016 Show Stuff
=====> 2016 Releases
=====> 2016 Previews
Pendraken Rules!
=====> BKC-III Rule Queries
=====> BKC-III Miniatures
=====> BKC-III Battles
Archive
===> Battleground 2017!
===> PPO 2017!
=====> 2017 Releases
=====> 2017 Previews
=====> 2017 Show Stuff
===> Post-War/Modern Photos
Archive
===> PPC 2018!
===> Battleground 2018!
=====> 2018 Show Stuff
=====> 2018 Releases
=====> 2018 Previews
=====> Older Releases
=====> Older Previews
Pendraken Rules!
=> Blitzkrieg Commander IV
===> BKC-IV Rule Queries
===> BKC-IV Miniatures
===> BKC-IV Battles
===> BKC-IV - Army Lists!
Archive
===> Battleground 2019!
=====> 2019 Show Stuff
=====> 2019 Releases
=====> 2019 Previews
Wider Wargaming
===> Proxy Figures/Models
===> Scams & Spams
=====> 2020 Show Stuff
=====> 2020 Releases
=====> 2020 Previews
Loading...
