10mm board size
Started by chalkie, 21 July 2014, 12:34:13 PM
chalkie
Hi, Is there a set size boardyou use for 10mm ? Iam going to
make some terrain boards or 10mm but was wonderingif there
was a set size. Paul.
I play BKCII on a 6'x4' table. For Dux Bellorum, on a 2'x2' or 3'x2' table. These are pretty much my default sizes for games. Hope this helps?
chalkie
Cheers Steve, yeh it does thanks.
Paul.
chalkie
So what size would you recommend for AWI & Napoleonics , ACW  ?
I would play on a 6'x4', with Black Powder as my preferred ruleset, for AWI, Nappies etc.
chalkie
Well you've sorted that for me mate.
Cheers.
Paul.
Sandinista
We play a lot of Pike & Shotte and Black Powder using an 8' x 5' table
chalkie
Thats a big table , you must field a very large force for that though , yes ? if anyone has any pics of there boards or tables I would love to see them out of curiosity.
If your rules are 'written for 28mm' with inch movement - use cms with 10mm.  The equivalent of a 6 x 4' table becomes 72cm x 48 cm.
We use 6'x4' a lot for 10mm, but also often use 9'x6' at my mate's.
We often play multi-player on the bigger table size, or really big armies.
I don't think there is anything like a standard table size. 6'x4' is probably the closest.
If you are making terrain boards I would probably go for 2'x2' and then they can be joined up to make bigger sizes.
Shedman
I play 10mm on 2x2, 4x3, 4x4 and 6x4 boards
ronan
hello
my board is almost always 6'' x 4''
We often convert inches to 2 cm ( 1'' = 2cm  instead of 2,54cm) It's easy for us, and the ranges are good.
We mainly play CoC, BKC, Might and Reason ( and some house rules for naval WW2 )
chalkie
Thats great lads, thanks. The modular boards are 2*2 but just wanted to know the average table for this scale but you have given me more scope with the various sizes you use.
very helpful, cheers,
Paul .
You might find this link useful Paul:
http://depotdelaguerre.com/EN/default.html
Some really very nice boards, which one day I will try and emulate...
chalkie
I will check it out.
cheers,
Paul
